P2-400 Ram 128 Mb M/B Gigabyte
VHS to VCD Needs work realtime ( 60-70 min in Cdr)
Good Quaility,Without Frame-drop,No Software Encode
Please recommend Capture Card for me
Thank you For EveryBody ;-)
About the best realtime VCD capture cards you can buy for the money are the ProVideo PV-231 and PV-233. Both cards do a great job of capturing realtime VCD, and as they both do the compression in hardware, you won't have to worry about frame drops or sync problems. Both cards use the Windbond compression chip, but the main difference between them is that the 233 has a tuner and remote, where the 231 does not. The 233 can also be set to start and stop a recording at a certain time. With a few registry tweaks, both of these cards will do the kind of quality you are looking for, and you need only a 233 mhz computer, so your P2-400 will work fine. I own one of these cards myself and the quality amazes me. You can buy the PV-231 for $85 online in the US and the PV-233 for $115 at the same place. These cards are sometimes listed on eBay, and there is a new ProVideo PV-233 on eBay right now for $95. Of all the cards I have tried out, I like these the best, as the quality is great and the audio never gets out of sync. Editing is not a problem, and even when edited, the audio stays in sync.
[off topic]
wow i wish i knew bout those [relativly] cheap ass hardware mpeg encoder cards when i still had my pent 2 4oo mhz
man ... only ones i ever found overhere was the dazzle n the winpvr witch were bloody damn expensive overhere
[off topic/]
Recommend Capture card/stick pls
By jubbely2 in forum Capturing and VCRReplies: 5Last Post: 27th Oct 2010, 13:14 -
Can any one recommend a tv capture card?
By Stevet1972 in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2009, 07:08 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 08:25 -
Recommend AGP 4x capture card for P4 2.4GHz computer please??
By w@ntonsoup in forum Capturing and VCRReplies: 16Last Post: 9th Oct 2007, 12:05
